Saltar al contenido principal
Oppo A37 A37fw 16GB viene con 2GB de RAM. El Oppo A37 ejecuta Android 5.1 y funciona con una batería no extraíble de 2630 mAh (según lo dicho por Oppo ;-). Lanzado por primera vez en abril de 2017.
I forget my password
I forget my mobile password so I rest my mobile how can you help me
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 20
11 comentarios
I don't know because I'm noob
- de
I forget my phone password
- de
My phone was hanging,strucking,heating,full of storage
- de
hard reset my phone total reset forgo passwod unlck
- de
how to remove mobile paswarod
=== Update (01/07/24) ===
how to remove mobile passwrod
- de
Mostrar 6 comentarios más
Agregar un comentario
12 Respuestas
Respuesta Más Útil
A factory reset should clear all data and restore to factory defaults.
Of course, this is a problem if your data isn't backed up as you will lose it all.
Fue útil esta respuesta?
Puntuación 7
Hi @ruggb,
A factory reset will reset the phone but it doesn't clear the password entirely.
If the phone has a Google account tied to it you still need to know the account ID and password to access the phone after a factory reset or know how to bypass the FRP lock (factory reset protection) that has been enabled in the phone by the reset to enable you to setup the phone again after the reset has been done. You only get so far into the setup procedure and no further as it asks for this information
FRP lock is a security feature in Android OS 5.1 and higher versions in case a phone was lost or stolen so that it couldn't be used again or onsold by simply resetting the phone back to its factory default condition as could be done with earlier versions of the OS
Puntuación 2
If you don't want lose your data you can use any tools for flashing or unlcock by any tool software. There are many tools you can use.
Puntuación 2
1 comentario:
كيف تبديل بطارية
- de
Locked phone
Puntuación 1
Lupa kata sandi
Puntuación 1
you need to Turn off the phone.
  • Ensure that the battery power is full or more than 50% on the device.
  • Press and hold the “Power Button and Volume Down Button” together for about 20 seconds.
  • When the Oppo logo appears on the screen, release both the buttons.
  • It will open a Menu page. Then select the “Language” option using the Volume up and volume down keys.
  • Press the Power button to confirm the command.
  • Select “Wipe Data” or “factory reset” option followed by selecting the “Yes” or the confirmation option.
  • As a final step, select Option “Reboot system
The Phone will continue the master reset, taking several minutes to complete. Once done, you will see your phone is brand new. This method of removing the pin pattern or wiping the data can be done on Phone pattern unlock without pc—no need to connect additional devices.
Puntuación 1
Lupa kata sandi dan pola
Puntuación 0
تبديل بطارية
Puntuación 0
Forgot password
Puntuación 0
forgot password
Puntuación 0
1 comentario:
not forget my oppo a37
- de
Forgot password
Puntuación 0
I have forgotten my password
Puntuación 0
Añadir tu respuesta
Muhammad Qasim estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 18
Ultimos 30 días: 70
Todo El Tiempo: 2,630
