Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
My Samsung galaxy F12 mobile is not getting charged with own charger
My Samsung Galaxy F12 mobile is not getting charged with its own charger but getting charged with only one another charger
Please help me with this situation
I've used 2 chargers majorly
One is output 5v
Another output 9v
But now the phone's accepting only 5v charger
Not 9v
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This might indicate that the original charger is broken
Fue útil esta respuesta?
Puntuación 1
1 comentario:
The phone's charger which came along with mobile isn't broken coz it's charging another things as usual
- de
@madmax94338 "charged with only one another charger" means you've tried multiple chargers. You need to let us know what the voltage outputs on those chargers are. In particular, we'd be interested in the voltages for the one that works. Also, there is a possibility that (if you tried other chargers) the USB-C port is having issues. Double check for that as well.
Update (07/18/23)
@madmax94338 this sounds like a daughter board issue. That is your charging board. Something like this one
Imagen
If that doesn't change anything, follow the Samsung flow chart and measure the components accordingly. The components are the ones the blue arrows are pointing to.
Imagen
Imagen
For any abnormality you find while you work on your phone, you can always add pictures to your Question. That way we can see what you see.
Agregar imágenes a una pregunta existente
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Puntuación 0
3 comentarios:
One is output 5v
Another output 9v
But phone is accepting only 5V charger now
Please assist me in this situation
The charger which came with phone is 9V
- de
So
According to u guys
This is a hardware problem?
- de
yes I would definitely look into the charging port
- de
Añadir tu respuesta
Madmax estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 582
