Saltar al contenido principal
Repair and information details for the KitchenAid Refrigerator KSRG25FK**1*, a side-by-side refrigerator with an ice dispenser and automatic defrosting feature, introduced in 2003. This page covers information for model numbers matching the pattern KSRG25FK**1*.
Preguntas 1 Ver todo
Water work but not the ice maker, no light on the switch
I have a KitchenAid side-by-side which I have installed new filters and new valve but ice maker does not work how do I troubleshoots what the issue so far I checked the temperature is okay the pipes are not clogged
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @meirf
Here's the icemaker service sheet that may help.
I couldn't find the wiring diagram for the refrigerator (Whirlpool part # 2255385) in case it is a power supply problem to the icemaker. You may have better luck.
Hopefully the problem is in the icemaker.
Update (07/16/23)
Hi @meirf
Found the tech sheet for the refrigerator.
Unfortunately it isn't much help as far as testing the icemaker switch is concerned as the wiring diagram is very basic as far as the modular icemaker is concerned. It is more for the refrigerator wiring overall and not for individual component internal wiring
It shows just the 3 wires i.e. White ( Neutral wire) and a Black/White (presumably power feed to the module) and a Tan wire which is used to operate the ice water valve.
To test it you would have to open it up.
Perhaps you should check first if power is getting to the icemaker.
The tech sheet states not to operate the icemaker cycle manually as it must be done electrically (see Note #4 on p.1) so perhaps you can initiate it using the service sheet I linked and then check if there's power on the BK/WH wire.
Be safety aware as the icemaker operates at 120V AC!
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you very much for your response is there a way to identified if the problem is the power or the switch?
- de
Añadir tu respuesta
Meir F estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 140
