dewatering after the wash
The machine was could not dewatering after the wash how to fix it
Es esta una buena pregunta?
Hi @nareshcn
Do you mean that the washer is not draining the water during or at the end of the wash?
If so, according to this parts supplier the service manual for the washer is LG MFL40322148. (Scroll down the list of parts to view the part number of the service manual to verify)
In the service manual go to p.28 and run the service mode tests as described and check what error codes (if any) show up.
If there's an 0E code (drain error) go to p.32 to see what to check.
If you get a different error code, find it in the manual (see p.31) and see what it shows to check.
If there is a faulty part, use the part supplier's list of parts linked above, to find the LG part number for the part and then search online for the part number, to find suppliers that suit you best.
Fue útil esta respuesta?
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 251
3 comentarios
The keyboard are not working
- de Kushagra Singh
Dewatering after the wash
- de R kanchana
@rkanchana
What is the model number of the washer?
- de jayeff
