Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Información de reparación y desmontaje del teléfono inteligente Pixel 7 Pro de Google, lanzado en octubre de 2022. Identificado por el número de modelo GP4BC y GE2AE.
I replaced my screen and now the phone seems to get stuck bootlooping?
I just replaced my screen as per the instructions and now it seems to be stuck in a boot loop. Screen comes on show "google' in color on the screen and them goes black and repeats. Not sure how to get it to run the calibration process.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
2 comentarios
Verify ifixit did not send you a pixel 6 pro screen like they did to me!
- de
The new problem screen has date code 20210305. The old scrren (also from IFIXIT in September) has date code 20210805.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
I am having the same issue and it seems to be something in the screen. If I put the old screen back in the phone immediately boots.
here is a video of the problem.. https://youtu.be/PwLwJ0E-DK0
UPDATE: Turns out they packaged Pixel 6 Pro screens in their Pixel 7 Pro kits! The two screens are extremely similar and it appears the hardware is technically compatible but the software is not.
Fue útil esta respuesta?
Puntuación 2
12 comentarios:
I am having the exact same issue. No response from support on this yet.
- de
I bought the replacement screen on Oct 9, 2023 for my google pixel 7 pro. And I have absolutely the same problem - old screen works fine, replacement screen only shows Google logo
- de
@konst83434 @jptaormina they likely sent you a pixel 6 Pro Screen! I took my phone and the ifixit screens to a ubreakifix and they confirmed the issue. I'm sure ifixit will make it right. It's obviously an easy mistake to make.
- de
I recorded video of the whole situation. I'll have a video posted soon.
- de
Mostrar 7 comentarios más
It sounds like either your replacement screen is faulty or that something wasn't done correctly during the replacement procedure. There could be many reasons for a device to bootloop, however, since this occured upon a screen change, it's most likely hardware related. It's mostly about power when we're talking about hardware-related bootlooping, and the phone not being able to draw the correct amount of current from the battery for it to function normally.
These could be some of the causes of this issue:
  • Something was incorrectly done during the repair, such as not properly connecting a cable.
  • Something was damaged during the repair, such as unintentionally stabbing a component on the motherboard.
  • The replacement screen is faulty.
I don't know where you bought the replacement screen from, but as long as it's not a cheap knockoff, it shouldn't be the issue on the first hand. Here's a link to a replacement screen from iFixit.
Troubleshooting
  • Turn off the phone, let it charge for a bit, and then try to turn it on again.
  • Open the phone up, take a close look and make sure that all the cables are properly connected and nothing looks broken.
  • Try the old display again and see if that works. If it does, you might be dealing with a faulty replacement screen. If that's the case, then contact the seller you got it from and ask if you can get a refund or a new display
  • Read the guide again and make sure that you've done everything correctly. Even errors that seem small could result in the repair not being successful. Also remember to read the description and other notes, as they might come in hand.
Imagen de Replace a front glass digitizer screen for a Google Pixel 7 Pro smartphone. Features a 6.7 inch 1440 x 3120 pixel AMOLED Display.
Producto
Google Pixel 7 Pro Screen - Genuine
$219.99
Puntuación 0
2 comentarios:
Nope they sent the wrong screen!
- de
I saw that, good thing you solved it! :-)
- de
@amjtech Thank you so much for posting your answer and adding your video! I've run into the exact same issue and I would not have realized why had you not written that post.
I do have a question though: My phone is currently stuck in a boot loop and I can't figure out how to turn it off safely. Should I just let it loop until the battery dies?
Puntuación 0
5 comentarios:
if you can put the old screen on the phone and you can see anything on the old screen you can use an OTG adapter if you have one and a mouse to turn the phone off.. if you already glued it back together yea just let it go dead
- de
@amjtech Unfortunately the old screen was so badly shattered it did not survive disassembly.
- de
Hold volume down and power button for 30 sec until recovery screen come up. Push volume up button then select power off.
- de
@azrockrunner Thanks! That worked!
- de
@azrockrunner I didn't think about that
- de
Añadir tu respuesta
Andrew Ewing estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 29
Todo El Tiempo: 2,566
