Why is my laptop beeping continuously?
I tried to turn on my laptop and found my laptop beeping continuously.What should I do to fix it?
Es esta una buena pregunta?
You should try checking with this HP guide. Your problem might vary from a dead CPU, to a simple reset. I've had similar issues with some Lenovo machines and the issues was solved with a simples reseat of the RAM. Good luck.
Fue útil esta respuesta?
None of them helped
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 28
Todo El Tiempo: 156
Hello, are the beeps in a sequence by chance, or is it just one long beep? If it is a sequence if you could count the beeps and reply that would be great!
- de BurtBen
No it's actually beeping like a car's blinker
- de Jackson King
Could you possibly record it and add it to the post?
Not sure how?:
Agregar imágenes a una pregunta existente
- de BurtBen
The beeps could indicate a fault. The number of beeps, as BurtBen suggested a recording, might help us diagnose the issue.
How old is the laptop?
- de JnCA
