Jbl partybox 110 no carga batería
hola comunidad! Tengo un problema. Tengo un Jbl partybox 110 y no carga la batería al conectar el cable! Eso tendría un fusible o algo en el conector? Desde ya muchas gracias
Es esta una buena pregunta?
Hola, como estás? Pudiste encontrarle solución a tu problema con el partybox?
Fue útil esta respuesta?
@roquegomez first you want to make sure that charger works properly. Measure it's voltage output and compare to that what it is supposed to be. Next check your charging cable. Make sure it does not have any bend, broken, corroded or otherwise damaged pins. Now clean your charging port. A few drops of isopropyl alcohol and a few puffs of compressed air will clean it up.
If your JBL Party Box still does not charge., it is time to open it up. Then check/replace the battery and check for proper voltages on the charging port where it connects to the circuit board. Not the greatest of all videos, but it may still work as a guide for you to work on your JBL. If you come across things that look "odd" post an images of it with your Question. That way we can see what you see.
https://es.ifixit.com/Gu%C3%ADa/Agregar+...
While you work on your speaker, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@roquegomez en primer lugar usted quiere asegurarse de que el cargador funciona correctamente. Mide su voltaje de salida y compáralo con el que se supone que debe ser. A continuación, compruebe el cable de carga. Asegúrate de que no tiene ninguna clavija doblada, rota, corroída o dañada. Limpia el puerto de carga. Unas gotas de alcohol isopropílico y unas bocanadas de aire comprimido lo limpiarán.
Si su JBL Party Box sigue sin cargar, es hora de abrirlo. A continuación, compruebe / reemplace la batería y compruebe si hay voltajes adecuados en el puerto de carga donde se conecta a la placa de circuito. No es el mejor de todos los vídeos, pero todavía puede funcionar como una guía para que usted pueda trabajar en su JBL. Si te encuentras con cosas que parecen "extrañas" publicar una imagen de la misma con su pregunta. De esa manera podemos ver lo que ves.
Mientras trabajas en tu altavoz, haz muchas fotos. Una vez que hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 112
Todo El Tiempo: 905
