My r3 ar move up from itself when I play ps4
My r3 move itself when I play ps4
Es esta una buena pregunta?
Do you mean that your right control stick moves by itself? If so, you might be experiencing stick drift. For the case of non-wear based stick drift, this may be caused by contamination of dust and other debris over time in the potentiometers. This guide shows a method to clean the relevant components that may help for this scenario.
Alternatively, if a solution like cleaning out debris does not work, the issue may be wear-based stick drift, in which case a replacement of the control stick module or the potentiometers may be appropriate. This is a process that requires desoldering the relevant components and installing new ones. Tutorials for this process can be found on Youtube.
Fue útil esta respuesta?
Stick drift. Ideally you need to replace the whole stick assembly on the circuit board which involves de soldering the old one and soldering on the new one.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 27
