usb connected, usb disconnected
when sometime i open my phone a notification shows usb connected/ usb disconnected and when i close my phone screen turns on again
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 38
@nxtraptor does it do that all the times or only sometimes? Anything common when it happens? What have you checked? What have you tried to fix this?
- de oldturkey03
Hi @nxtraptor,
Use a strong light and a magnifying glass to inspect the USB charge port for any bent or broken pins or if there's any debris lodged in the port enclosure.
If there is some debris, do not use a metal pin or probe to try and clear it. Try using a vacuum cleaner or a wooden toothpick instead.
- de jayeff
