Mi pantalla se ve negra pero si se escucha
Es esta una buena pregunta?
Casi seguro averia del modulo backlight Luz trasera de la pantalla, pide presupuesto en el servicio tecnico, la factura no bajará de 130€ evalua segun la antiguedad del aparato si merece la pena reparar.
Fue útil esta respuesta?
@edisonpier57204 I agree with my colleague @carloslope27326 on this. It does sound like a backlight strip issue, but you can never rule out the T-Con board. We will of course need to know your TV's exact model number. In the meantime, try this:
First you need to verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
Turn the TV on and to a channel where you can hear the sound. Now, in a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Agregar imágenes a una pregunta existente for that so we can see what you see. It is possible that this is a T-con board issue.
Sorry for having to translate this, but my little bit of Spanish would probably be more offending than helpful.
Translation
@edisonpier57204 Estoy de acuerdo con mi compañero @carloslope27326 en esto. Sí que parece un problema de la tira de retroiluminación, pero nunca se puede descartar la placa T-Con. Por supuesto, necesitaremos saber el número de modelo exacto de tu televisor. Mientras tanto, intente lo siguiente:
Primero tienes que verificar que no tienes imagen en todas las entradas. Si permanece oscura, desenchúfala y pulsa el botón de encendido durante un minuto, luego vuelve a enchufarla. Comprueba si así se reinicia el televisor.
Enciende el televisor y ponlo en un canal en el que puedas oír el sonido. Ahora, en una habitación a oscuras, utiliza una linterna y dirige el haz de luz en ángulo contra la pantalla. Comprueba si distingues sombras o formas. Si es así, es que la retroiluminación ha fallado. Si no ve nada, desenchufe el aparato y retire la parte trasera. A continuación, compruebe visualmente que las placas no presentan daños evidentes, como condensadores abombados o con fugas. Compruebe todo el cableado y desenchufe los cables y vuelva a enchufarlos para asegurarse de que están bien asentados. Publica algunas imágenes de todas tus placas con tu pregunta. Utilice esta guía Agregar imágenes a una pregunta existente para que podamos ver lo que usted ve. Es posible que se trate de un problema de la placa T-con.
Lo siento por tener que traducir esto, pero mi poco de español probablemente sería más ofensivo que útil.
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 163
