¿Porque mi portátil no enciende?
No enciende de ninguna forma
Es esta una buena pregunta?
@santiagoandr502 start with the basics. Check your power supply with a multimeter. Make sure that the output is 19V. Then check the charging port. Make sure it is not bend, corroded or otherwise damage. Clean it with a few drops of isopropyl alcohol and a few puffs of compressed air. Next you will have to open your Mini 110 up.
Now check the DC power jack for power on the inside when you plug the power supply in. If you don't have any voltage, or lower than 19V you may have to replace the jack. Luckily, on this model it can easily be replaced since it has its own cable etc. If none of this works, you may have some issue on the motherboard. For that we really would need to see what board it is. Post some good pictures of the motherboard with your Question. That way we can see what you see. https://es.ifixit.com/Gu%C3%ADa/Agregar+...
To work on your Mini use this HP Mini 110 Maintenance And Service Manual It is in english only, but a good translation program should make it useful for you too.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://es.ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@santiagoandr502 empieza por lo básico. Comprueba tu fuente de alimentación con un polímetro. Asegúrate de que la salida es de 19V. Luego comprueba el puerto de carga. Asegúrate de que no está doblado, corroído o dañado de alguna manera. Límpialo con unas gotas de alcohol isopropílico y unas bocanadas de aire comprimido. A continuación tendrás que abrir tu Mini 110.
Ahora comprueba si hay tensión en el conector de alimentación de CC por dentro cuando enchufes la fuente de alimentación. Si no tiene tensión, o es inferior a 19 V, es posible que tengas que sustituir la clavija. Por suerte, en este modelo se puede sustituir fácilmente ya que tiene su propio cable, etc. Si nada de esto funciona, puede que tengas algún problema en la placa base. Para eso sí que necesitaríamos ver de qué placa se trata. Publica algunas buenas fotos de la placa base con tu pregunta. Así podremos ver lo que tú ves. https://es.ifixit.com/Gu%C3%ADa/Agregar+...
Para trabajar en tu Mini usa este HP Mini 110 Maintenance And Service Manual Está sólo en inglés, pero un buen programa de traducción debería hacerlo útil para ti también.
Mientras trabajas en tu portátil, haz muchas fotos. Una vez que hayas terminado con él, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 55
