Saltar al contenido principal
Guías de reparación y soporte para la línea de portátiles orientados al consumidor de Lenovo, la serie IdeaPad, anunciada por primera vez en enero de 2008.
Preguntas 707 Ver todo
Porque no se ve el brillo de la pantalla
Tengo una Lenovo Ideapad S145 pero cuando enciende no se ve el brillo, se que es el backlight pero no encuentro donde adquirir el componente y alguna manera de cambiarlo, por lo que se es reparación de motherboard
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@davetec it could be the backlight strips in your display assembly or it could be issues on the motherboard. The common way of testing it would be by measuring the voltages on your display connector. Teh backlight will need a higher voltages. Your contact 1&2 on the display connector are the ones for the LCD power. Check the voltages on those two points. On pin 1 and 2 you should have 20.1V and on Pin 15 should be 3.3V. If you show that voltage on your connector, you know it is your LCD. If you do not have the higher voltages, the issue will be on the motherboard. Check your backlight fuse F3301 for power and continuity.
Download the maintenance manual from here It will be in english but you could probably use some translation software to make use of it. Get to the display connector and do some measurements. Let us know what you find out.
You can post pictures of what you are working on, with your QUESTION. Just in case you need more details or a bit more help.
While you work on your computer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://es.ifixit.com/Guide/new The iFixit community will appreciate this.
Translation
@davetec pueden ser las tiras de retroiluminación de la pantalla o problemas en la placa base. La forma habitual de comprobarlo sería midiendo los voltajes en el conector de la pantalla. La retroiluminación necesita un voltaje más alto. Los contactos 1 y 2 del conector de la pantalla son los que alimentan el LCD. Comprueba los voltajes en esos dos puntos. En el pin 1 y 2 debe tener 20.1V y en el pin 15 debe ser 3.3V Si muestra ese voltaje en su conector, usted sabe que es su LCD. Si usted no tiene los voltajes más altos, el problema estará en la placa base. Compruebe el fusible de la luz de fondo F3301 para la energía y la continuidad.
Descarga el manual de mantenimiento desde aquí Estará en inglés pero probablemente puedas utilizar algún software de traducción para utilizarlo. Ve al conector de la pantalla y haz algunas mediciones. Haznos saber lo que averigües.
Puedes publicar fotos de lo que estás trabajando, con tu PREGUNTA. Sólo en caso de que necesites más detalles o un poco más de ayuda.
Mientras trabajas en tu ordenador, haz muchas fotos. Una vez que hayas terminado con él, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
https://es.ifixit.com/Gu%C3%ADa/Agregar+...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
David Martinez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 79
