Why is my GameCube turning off suddenly?
My GameCube turns off when I least expect it to. I didn't even touch the power button. What should I do about that.
Es esta una buena pregunta?
@sethturner50892 just like @andrewsawesome already said, time to take it apart. Yor GameCube could be over 20 years old and things happen when age creeps up. Use these guides Nintendo GameCube to work on it. Clean the fan, check the capacitors and check the traces on all boards, for corrosion. That is pretty common after that long time. If unclear or if anything looks odd, you can always post some images with your Question Agregar imágenes a una pregunta existente
If you are still using the original power supply, then check the output voltage on it. Wiggle the cable and see if that turns off the output. Of course, you will need a multimeter for that.
Fue útil esta respuesta?
Probably full of dust. A new clean should help.
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 47
Todo El Tiempo: 336
@sethturner50892 Have you checked that the power supply is good and there are no bulged, burnt or blown components?
- de Andrew S
