LG Smart TV 42" después un golpe no quiere ver imagine?
Porque mi LG Smart TV 42" después un golpe no quiere ver imagine hay sonido pero no hay imagen ?
Es esta una buena pregunta?
En LG es muy tipico la averia del modulo de retroiluminacion Back light.
Fue útil esta respuesta?
@petersonva25598 something may get lost in translation. It sounds like there is some damage to the LCD. If it was physical damage, it is possible that this is a broken LCD? If it was internal damage from things like thunderstorm or anything like that, it may be the T-con board or the LCD. We would need to see what your TV screen shows you. But try this first.
First you need to verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and shine it at an angle against the screen (in a darkened room) with the TV at a channel where you can hear the sound. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Agregar imágenes a una pregunta existente for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Translation
@petersonva25598 algo puede perderse en la traducción. Suena como si hubiera algún daño en la pantalla LCD. Si fue un daño físico, es posible que se trate de un LCD roto? Si fue daño interno por cosas como tormenta eléctrica o algo así, puede ser la placa T-con o el LCD. Tendríamos que ver lo que te muestra la pantalla de tu TV. Pero intenta esto primero.
Primero necesitas verificar que no tienes imagen en todas las entradas. Si permanece oscura, desenchúfala y pulsa el botón de encendido durante un minuto, luego vuelve a enchufarla. Comprueba si así se reinicia el televisor.
Si sigue a oscuras, utiliza una linterna y apúntala en ángulo contra la pantalla (en una habitación a oscuras) con el televisor en un canal en el que puedas oír el sonido. Comprueba si distingues sombras o formas. Si es así, es que ha fallado la retroiluminación. Si no ve nada, desenchufe el televisor y retire la tapa trasera. A continuación, compruebe visualmente que las placas no presentan daños evidentes, como condensadores abombados o con fugas. Compruebe todo el cableado y desenchufe los cables y vuelva a enchufarlos para asegurarse de que están bien asentados. Publica algunas imágenes de todas tus placas con tu pregunta. Utilice esta guía Agregar imágenes a una pregunta existente para que podamos ver lo que usted ve. Es posible que sea un problema de la placa de potencia o de la placa T-con.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 272
