Laptop Battery is not Working
My Laptop Battery Is Not Working It Is Just Work with Connecting Charger otherwise It Is has been Shutdown When charge is not connected
Es esta una buena pregunta?
Hi Baseer,
seems like you're having a battery issue: to check your battery health on Windows, enter the command "powercfg /batteryreport" in a Powershell terminal and press enter, then simply open the generated HTML report file; read this how-to to learn more about the procedure. On GNU/Linux, you may want to try some command-line utilities like Upower, acpi, cat/find, Batstat and battery-level-cli; check out this article to learn more about the commands usage.
If the battery is drained or visibly swollen, it's time to buy a new one.
Finally, I suggest you check out this article, that will give you some tips on how to make your battery last longer
Fue útil esta respuesta?
Maybe the battery is broken, you can replace with a new battery to try it.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 140
1 comentario
Hi @baseerhashmi,
Please verify the model number of the laptop as shown on the information label on the bottom of the laptop?
The model you selected is a desktop computer and it doesn't have a battery
- de jayeff
