Saltar al contenido principal
El teléfono inteligente de primera línea de Apple para 2020. Anunciado el 13 de octubre y lanzado el 13 de noviembre, el iPhone 12 Pro Max tiene una pantalla OLED de 6.7 ", un sistema de cámara trasera triple con LiDAR y conectividad 5G. Sucesor del iPhone 11 profesional máx.
Preguntas 20 Ver todo
Which lens cover goes where?
I have problems with the Ultra wide angle camera on my iPhone 12 Pro Max (eu version) it has dust inside, so i wanted to clean it inside witch it means the lens cover needed to be repalaced, i got the replacement part but sadly i don't know lens goes where
https://we.tl/t-1uZZ5a4CkO
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi @boostedwilliam,
I don't know the answer to your question; you'll probably have to compare the black rings on the replacement lenses to those on the phone and match them up according to the width of those rings.
However, there is an alternative that I assume you've already rejected, but here it is anyway.
Instead of attempting to remove those pieces of glass, you could instead open up the phone and remove the cameras themselves. That would allow you to use compressed air and/or a vacuum to clean out the cavity and the camera thoroughly and ensure you've got everything; you'll be able to do a much more complete job than just by removing the glass lenses. Here's an iFixit guide showing you exactly how to pull those cameras out for cleaning.
iPhone 12 Pro Max Rear-Facing Cameras Replacement - iFixit Repair Guide
You also risk breaking the lenses when you're trying to get them out, which could drop shards of glass into the camera, making things worse.
Your choice, of course, but something to consider.
Fue útil esta respuesta?
Puntuación 1
Wide angle camera blurry
Puntuación 0
Añadir tu respuesta
Boosted_William estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 219
