Saltar al contenido principal
Envío gratis en pedidos nacionales de $75 o más
El Moto G4 Plus es una mejora del Moto G4 de Motorola. El Moto G4 Plus ofrece un sensor de huella dactilar, mayor capacidad de memoria y una cámara trasera mejorada. Números de modelo XT1642 y XT1644.
My display remains greenish all the time
Recently I has dropped my phone into water then the camera module get moisture. That time I was very hyper then took it to a phone servicing centre and clean the moisture but the display got tint issue......and also ghost touch issur.....my display remains greenish all the time .. what can i do now??
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@srtechente59078 At this point the most obvious solution for you is to replace your screen. Since both the LCD and the digitizer are contained in the display assembly, replacing it should solve all of the problems you're seeing.
The good news is your prompt action with getting the phone cleaned probably saved it, but displays are notoriously sensitive to liquid damage.
Replacing the screen is something you can do yourself, but if you're not comfortable then you'll want to take it to a service center to have the repair done. Here's the iFixit guide that will take you through the procedure step by step.
Motorola Moto G4 Plus LCD Screen and Digitizer Assembly Replacement - iFixit Repair Guide
You can buy a replacement screen right here on iFixit or go shopping yourself on places like Amazon, eBay and AliExpress.
Moto G4 Plus Screen: LCD Display + Digitizer Replacement Kit - iFixit
If you don't have the tools already, I'd recommend the Fix Kit version. For an extra $6 USD you will get all the tools needed to open up the phone, remove all the internals and replace them into a new display, along with all the adhesives needed to put the phone back together again.
Imagen de Replace a front glass digitizer panel compatible with the Motorola Moto G4 Plus model XT1641 smartphone. 5.5 inch 1080 x 1920 pixel LCD Display. Includes the LCD display, front plastic and metal frame, edge bezel, battery adhesive, earpiece speaker, fingerprint sensor, and vibrator motor.
Producto
Moto G4 Plus Screen - Genuine
$29.99
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
S&R Tech& Entertainment estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 235
