Saltar al contenido principal
A samsung laptop released in 2016, identified by Model Code: NP740U5M - X01US
Why is my keyboard backlight not working anymore?
I, lately just rebooted my Samsung Notebook 7 Spin with Tiny11, but now my keyboard backlight wont work and now I'm stuck with a lightless keyboard. Is there any way I could fix this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Hi @steventav38109,
Have you checked the settings in Control Panel > Keyboard?
Tiny 11 is a cut down Win 11 edition so maybe the keyboard backlighting isn't a feature that catered for.
- de
Agregar un comentario
1 Respuesta
If your Samsung Notebook 7 Spin keyboard backlight is not working after rebooting with Tiny11, there are several things you can try to fix the issue:
  1. Check keyboard backlight settings: Sometimes, the keyboard backlight might be turned off in the settings. Check the keyboard backlight settings and make sure it is turned on.
  2. Update drivers: Outdated drivers can also cause issues with the keyboard backlight. Go to the Samsung support website and download the latest drivers for your Notebook 7 Spin. Install them and check if the backlight works.
  3. Check for hardware issues: There might be a hardware issue causing the keyboard backlight to not work. Check the keyboard connection to the motherboard and make sure it is securely connected. You might also want to try cleaning the keyboard contacts with compressed air.
  4. Try a system restore: If the issue started after installing Tiny11, try doing a system restore to a previous point before you installed it. This will restore your computer to a previous state and might fix the issue.
If none of these solutions work, it is recommended to seek professional help or contact Samsung support for further assistance.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Steven Tav estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,197
