Samsung Freezer not freezing (French door) RF4287HARS/XAA
So we were actually given this fridge since it stopped working as a project, the freezer does not work, sometimes it'll freeze but it takes a very very very long time to freeze (About 3 days to fully freeze something) so I believe it does get below freezing temps
however I believe it might be the display because the display says the temps are right and then about an hour later they say it's -8 when it's only 38*F inside the freezer.
Components Replaced:
Compressor (It leaked refrigerant when we got it, and then the motor locked up so we had it replaced) We didn't replace it someone else did, we have a friend who works in hvac and does fridge repairs
Temp Sensors in the freezer (Both the defrost temp sensor & the regular freezer temp sensors in the ceiling)
Main PCB (Bit of a story I bought a remanned one from amazon replaced it, but the freezer stopped freezing entirely... like even after 6 to 8 hours it was still at room temp.)
I'm more leaning towards the Main PCB (See the comment above as to why if it freezes before on the old pcb but takes 6 to 8 hours but the remanned board doesn't) my real question is do I buy the bullet and get a new pcb from a supplier or do I buy that control panel with the temp display on it that keeps redirecting to the auto set temp after an hour when the freezer still sits at 38*F
or is there something else I'm missing?
Es esta una buena pregunta?
