Jorge Hernandez for now you want to stop continuing to try to charge, sync or otherwise use your watch. This potentially can make a bad situation worse. This may further damage your watch.
The next thing to do is to clean it. Disassemble your watch using [these guides]. You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with at least+90% isopropyl alcohol. Follow this guide , and even so it was written for an Apple iPhone 3G, all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, you must replace the battery. All these steps are to avoid delayed failure caused by corrosion which might happen fast and furious if your watch fell in Saltwater. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your watch and reevaluate. Until it is cleaned, everything will only be a guess. We understand your frustration but even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
If you are unsure of anything or get stuck with anything, post a couple of good pictures with your QUESTION. That way we can see what you see. Also, it might be good to see the board/watch before cleaning so we can evaluate the corrosion damage. ******
https://es.ifixit.com/Gu%C3%ADa/Agregar+...
TRANSLATION
Jorge Hernández por ahora su deseo de dejar de seguir tratando de cargar, sincronizar o utilizar de otra manera su reloj. Esto potencialmente puede empeorar una mala situación. Esto puede dañar aún más su reloj.
Lo siguiente que debe hacer es limpiarlo. Desmonte su reloj utilizando [estas guías]. Debe quitar todos los escudos EMI. Si no los quita, es mejor que no haga nada. Después de quitarlos, limpia toda la placa, conectores y todo con al menos +90% de alcohol isopropílico. Sigue this guide, y aunque fue escrita para un Apple iPhone 3G, todos los puntos son pertinentes para tu teléfono. Mientras limpias la placa, comprueba que no haya daños evidentes, como componentes quemados o que falten, etc. Cuando esté bien limpia, debes sustituir la batería. Todos estos pasos son para evitar el fallo retardado causado por la corrosión que podría suceder rápida y furiosamente si su reloj cayera en Agua Salada. Lo mejor sería limpiarlo con un limpiador ultrasónico, pero si no tienes acceso a uno, esto al menos te ayudará. Una vez hecho esto, vuelva a montar el reloj y evalúelo de nuevo. Hasta que no se limpie, todo serán suposiciones. Entendemos su frustración, pero incluso con todo esto, los daños causados por el agua sólo tienen una pequeña posibilidad de ser reparados por completo, pero al menos puede intentarlo.
Si no estás seguro de algo o te quedas atascado con algo, publica un par de buenas fotos con tu PREGUNTA. Así podremos ver lo que tú ves. Además, sería bueno ver el tablero/reloj antes de limpiarlo para que podamos evaluar los daños por corrosión
No te engañaron, un aparato electronico que lleva una pila o bateria , al que le ha entrado agua salada de mar, lo puedes tirar directamente, todo el interior estara sulfatado y quemado. Lo siento, no quiero darte esperanzas en reparar algo que es inviable.
- de Carlos López (España - Spain)
