No enciende mi dispositivo
Samsung Galaxy J4 Core
Se mojo mi celular y quiero repararlo
Es esta una buena pregunta?
Emanuel Jesús Ortiz May for now, you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse, by creating more short circuits etc.
After that you must treat it the same way as you would any other water damaged phone.
Disassemble your phone using something like this video You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for an apple iPhone 3G, all the points are still pertinent to your phone as well. While you clean your board, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Here is the troubleshooting part of the service manual for your phone. It is written in English but I do hope you can make use of it. If you are running into any issues, post some good pictures with your Question. That way we can see what you see.
Until all of the parts are cleaned, everything will only be a guess. Even after all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Take lots of pictures when you start working on your phone. That way you can create a guide for the iFixit Community. That will make it easier for the next person that may have the same issue with their phone. It's fun and easy to create those guides. The iFixit community will thank you for it.
TRANSLATION
Emanuel Jesús Ortiz Por ahora, es mejor que dejes de intentar cargar, sincronizar o utilizar tu teléfono. Esto potencialmente puede empeorar una mala situación, creando más cortocircuitos, etc.
Después de que usted debe tratar de la misma manera como lo haría con cualquier otro teléfono dañado por el agua.
Desmonte su teléfono usando algo como este video Debe quitar todos los escudos EMI. Si no los quitas, es mejor que no hagas nada. Después de quitarlos, limpia toda la placa, conectores y todo con +90% de alcohol isopropílico. Siga esta guía, y aunque fue escrita para un iPhone 3G de Apple, todos los puntos son pertinentes para su teléfono también. Mientras limpias la placa, comprueba que no haya daños evidentes, como componentes quemados o que falten, etc. Cuando esté bien limpia, sustituye la batería. Todos estos pasos son para evitar el fallo retardado causado por la corrosión. Lo mejor sería limpiarla con un limpiador ultrasónico, pero si no tienes acceso a uno, esto al menos te ayudará. Una vez hecho esto, vuelva a montar el teléfono y vuelva a evaluarlo. Aquí está la parte de solución de problemas del manual de servicio [documento|28528]para su teléfono. Está escrito en inglés, pero espero que puedas utilizarlo. Si usted se está ejecutando en cualquier problema, publicar algunas buenas fotos con su pregunta. De esa manera podemos ver lo que ves. https://es.ifixit.com/Gu%C3%ADa/Agregar+...
Hasta que no se limpien todas las piezas, todo será sólo una suposición. Incluso después de todo esto, los daños por agua sólo tienen una pequeña posibilidad de ser reparados completamente, pero al menos puedes intentarlo.
Toma muchas fotos cuando empieces a trabajar en tu teléfono. Así podrás crear una guía para la Comunidad iFixit. Eso hará que sea más fácil para la próxima persona que pueda tener el mismo problema con su teléfono. Es divertido y fácil crear esas guías. La comunidad iFixit te lo agradecerá.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 103
