Saltar al contenido principal
Launched in 2012, the Asus X54C features an Intel Pentium Intel® Core™ i3 Processor, Intel® Pentium® Dual-Core Processor and Intel® Celeron® Dual-Core Processor
What is the maximum amount of ram supported?
I own this laptop, which came modded with a 500 gb ssd (Which seems to be working fine) and 12 gb of ram. However, the laptop has been having issues with battery. The battery only lasts around 3 minutes, and it jumps from 90% to 0 in an instant. While I am not sure if this is just how old the battery is, or if the max supported power level was exceeded by both the ram and ssd. I am not sure of the brand of said ssd or ram, but the ram was added in addition to the original 4 gb ram with a 8 gb addition.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Officially the max amount of ram is 8GB i.e. 4GB fixed + 4GB removable but if it works OK with 12GB when the charger is connected it sounds more like a battery problem than a problem with the memory.
Check the condition of the battery by creating a battery report
When you have the report compare the Design Capacity value against the Full Charge capacity value. For a good battery they are nearly the same value. You can work out as a % how good the battery still is i.e Full charge capacity value x 100 / Design capacity value
If it is determined that the battery needs replacing, find the battery model number (or Asus part number) printed on the battery and use that information when searching online for suppliers. Here's the ifixit Asus X54C Battery Replacement guide that may help.
Here's a link that will help you to find information regarding the ram in the laptop. Note: This uses the Command window which is old time computing i.e. the mouse doesn't work in the window. If you make a typing error use the backspace key to step back and delete what you have already typed in, back to the point of the error and start typing again.
The laptop uses DDR3L-1600 (PC3L-12800) SODIMM ram.
The model number of the SSD can be easily found in Device Manager > Disk drives. Once you know the model number search online using the number to find out the maker of the SSD.
To get to Device Manager in Win10/11 press the Win key + x key (both together) and click on the Device Manager link that appears in the menu box.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Willow Eckles estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 42
Todo El Tiempo: 722
