Saltar al contenido principal
The Lenovo G500s Touch was released in June 2013. The G500s is an entry-level laptop that features a slim design and an affordable cost offering the best cost-effective laptop.
Preguntas 4 Ver todo
when I turn it on the small lights light up but the screen is black?
those lights blink 3 times then stop blinking the battery light is red
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
Hi,
Have you tried charging the battery?
- de
thats the thing it was red for a long time but one time it lit up said something error choose something then before i read it quickly shut down
- de
Agregar un comentario
1 Respuesta
Hi,
Disconnect the charger if connected and then remove the battery from the laptop and then plug in the charger to the laptop and check if it turns on OK
Here's the hardware maintenance manual for the laptop. Go to p.35 to view the procedure to remove the battery pack.
If it turns on OK then the battery is faulty and needs to be replaced.
Search online for 121500171 to find suppliers that suit you best.
Fue útil esta respuesta?
Puntuación 0
7 comentarios:
it doesnt work there is no light the blinkers dont even light up
- de
@masresha geremew
Check that there is 20V DC at the output plug of the charger.
If the charger isn't supplying enough voltage it can't charge the battery or turn on the laptop.
If the charger's output is OK then it looks like it needs a battery inserted to power on. Was worth a try as a lot of laptops will work without the battery inserted when the charger is connected..
The laptop will need to be opened and tested further as to what the problem is
- de
Everything about
the charger is fine so wht should i do
- de
@masresha geremew
You would need to use the schematics for the motherboard and start checking the power supplies on the motherboard.
if you can't read schematics contact a reputable, professional laptop repair service and ask for a quote to repair the laptop.
- de
oh wait it just turned white should i come back and ask u if the pc turns on ill let it charge for an hour
- de
Mostrar 2 comentarios más
Añadir tu respuesta
masresha geremew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 64
