Saltar al contenido principal
Reparación y solución de problemas del dispositivo calculadora científica TI-30Xa.
Preguntas 9 Ver todo
Certain Buttons Won’t Work
The 1,5 and subtraction button on my calculator won’t work. Can this be fixed or should I just buy a new one?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios
A goggle search shows current (2022) prices between $13-$22. Electronic calculators in general are not repairable.
- de
@Papaya Bear
I suggest that you have a look at the excellent answer from @jayeff below:-)
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
Use a Q-Tip lightly moistened (not dripping wet) with Isopropyl Alcohol 99%+ (available at electronics parts stores) to clean the contact surfaces of the board for the buttons that don't work.
Do not clean the contact surfaces of the buttons themselves as you may remove the conductive coating from the underside of the button.
Here's the ifixit Texas Instruments TI-30Xa Teardown guide that will help. Go to Step.5 to view the image of the board showing the button contacts on the board.
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
Papaya Bear estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 305
