820-00134-A iMac 27" Late 2015 - No display, backlight works
Hello
I received 27" iMac, Late 2015 model that's broken. I don't know what exactly happened but it appears to be unopened and there are no marks indicating prior repair attempts.
Initially it didn't display anything on the screen and backlight didn't work. Only 2 diagnostic LEDs would light up and 3rd was very faint. I opened it and found F4400 fuse near eDP connector to be blown. Replaced it with a suitable part and backlight came back to life. Unfortunately it still doesn't display anything on the screen. Now I get 4 green diagnostic LEDs.
I can hear the chime and also I can adjust brightness using keyboard buttons.
What I've tried so far:
- replaced F4400 fuse
- tried removing coin battery
- tried booting it without Blade SSD
- tried booting it with audio jack PCB disconnected
- tried reflashing EFI with one found online, also tried cleaning ME region in the original EFI
- checked eDP connector both on the logic board and TCON
- checked main fuse and all filters on TCON module
- I get 0.9 Ohms reading on GPU coils but I assume it's okay for a GPU
I know the next logical step will be to try my iMac with an external display but I haven't received the adapter yet. Ultimately I wanted to convert it into 5K display but I thought it would be nice to fix it first to make sure the LCD is fine.
Do you have any other clues?
My iMac has 820-00134-A logic board.
Es esta una buena pregunta?
5 comentarios
@webhdx post some good pictures of what you refer to as the T-con module. Agregar imágenes a una pregunta existente
- de oldturkey03
By TCON I mean display driver in the panel itself. This is the module where other end of eDP cable connects to. Sorry I have no pictures for now as the iMac is in the workshop. The module looked fine, no visible damage. Also all flex cables connecting it with the panel looked good.
- de webhdx
Yes, there is 12V on the eDP connector and it was restored by replacing F4400 fuse. This resulted in backlight coming back to life. Sadly still no image.
- de webhdx
@webhdx I guess you really need to wait until you have your external display adapter. this sounds like a video signal more than anything else. Any idea what happened that made the fuse blow? You said it's a late 2015 with a 820-00134 It should be a 5K display already. Do you have the number for the display?
- de oldturkey03
Unfortunately I don't know the history of this iMac. I got it in this state and it appeared to be unopened. The display is LM270QQ1(SD)(B1) model. It's Retina 5K panel.
- de webhdx
