Are the power supply for a 1908 and 1907 interchangeable?
I have a 1908FPT with the 2-second display problem, it will display for a couple of seconds at power up then go dark. what i've read is this can usually be resolved by swapping out the internal power supply board (probably a capacity or two has leaked). i have a 1907FPC that does work but has a lower resolution.
can i pull the power supply board from the 1907FPC and replace the power supply board in the 1908FPT? i'm perfectly happy sacrificing the 1280x1024 monitor to resurrect the 1920x1080 monitor if the power boards are compatible.
Thanks
Es esta una buena pregunta?
