Soket of charge not work good
Es esta una buena pregunta?
Hi,
Use a strong light and a magnifying glass and check that the USB charge port enclosure is free from any lint etc that may be preventing a good electrical connection.
Also ensure that the pins are all there and that they're straight a parallel with each other and not bent etc.
If there is any debris in the port enclosure, do not use a metal pin or probe to remove it as you may damage the pins. Try removing it by using a vacuum cleaner instead.
If the port seems OK then perhaps it is a loose USB connection on the charge board in the phone. The phone would have to be opened and the port further checked.
Here's a video that shows how to replace the charge port (supplier examples only) that may help.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 26
