Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lanzados a finales de 1993, Macintosh Quadra 610 y Macintosh Centris 610 son dos ordenadores personales estrechamente relacionados que forman parte de las series Quadra y Centris de Apple Computer, respectivamente.
Why won't the computer start?
no image start up on monitor
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Any sounds? Does the motherboard runs? Do you hear power supply unit working?
There may be many reasons:
- power supply is dead (if nothing happens after power-on)
- battery is dead
- chipset is dead
- memory is dead
- tarnished contacts (power is not supplied to motherboard at all, or not enough power for components)
opix.pl
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
replace battery, and it does not work--- hear not working tune;
hit option command R and P along with start button, and does not work--- hear not working tune,
- de
also, green light comes on, but no screen picture, just the not working tune.
- de
In addition, the computer worked the last time I used it 15 years ago, that's why I thought replacing dead lithium ion batter would revive it, but no, just the I'm not working tune plays. In additon, I can hear the hard drive, and fans working.
- de
it is more possible that the video wire may be broken, or the VGA adapter is corrupted (try by AV cables if you connected it earlier via adapter). If not I would open the chassis and look for solder cracks. Ah sorry I didn't noticed you mentioned not working tune - focus on the hardware, skip video wires, I was wrong.
- de
The first thing I would do is install an new 3.6 volt 1/2 aa Lithium PRAM battery.
You can get it here: https://www.amazon.com/Brand-LS14250-Lit...
Puntuación 0
1 comentario:
good choice for 1st step - usually computers do not die if not used, but internal batteries runs out :)
- de
Añadir tu respuesta
Denton Fender estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 536
