Whirlpool Built In Top Control Dishwasher Arms Not Moving
Have a Whirlpool Top Control Built In dishwasher and the spray arms are not working.
I have checked to make sure water flows through them and cleaned trap etc. I need to get in to check that the pump isn’t clogged. How do you access it? I’ve attempted to find manuals but nothing shows how to access the main spot that pushes water through them. I was able to detach the back one tubing and that is not clogged.
Update (01/10/2023)
I had to Google since unable to tell based on tag.
Es esta una buena pregunta?
2 comentarios
Hi @dishproblem
What is the model number of the dishwasher?
Can you hear if the wash pump is operating when the dishwasher is turned on or it is only "buzzing" as if trying to rotate?
- de jayeff
WDT540HAMZ
The water is pumped in, it drains fine, it seems to run a whole cycle without arm movement/water going through arms.
- de Deidre
