Saltar al contenido principal
Modelo A1347 con procesador Core 2 Duo de 2.4 o 2.66 GHz.
What connector is needed in a ssd upgrade
I plan on upgrading to a 2tb ssd what sata connector do I need to ensure that my efforts will be successful? Thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
This Mac Mini natively supports 2.5” SATA drives. So no connectors or adapters are necessary.The SATA connector itself is quite standard so just about any 2.5” SATA drive should fit. There are upgrade kits available that will ensure the correct drive, plus necessary tools, although it does not appear they have a 2TB kit if that’s what you are after.
Did you have a specific drive in mind?
Imagen de Upgrade the storage and improve boot time and read/write speed in your Mac mini Unibody with this SSD upgrade kit.
Producto
Mac mini Unibody SSD Upgrade Kit
$62.99
Fue útil esta respuesta?
Puntuación 1
1 comentario:
If you want to extend your internal storage you could move the HDD to this Instalación del disco doble en Mac mini mediados 2010 and then use the HDD port for the SSD. That way you get the best setup.
- de
Añadir tu respuesta
deweydewman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 141
