windows button is not working
Es esta una buena pregunta?
got the same issue. wasted my two days try to find out what was wrong, well maybe a bit late but here is what happened
you may enabled the STUPID Win key disable function by accidentally pressed the Fn and Win, which is conveniently placed NEXT TO EACH OTHER, and just make things worse, there is no indicator light like the caplock, so good luck to find that out. Thanks Asus
Fue útil esta respuesta?
Wow! Amazing!!
You helped me the most
I spent a few hours trying to restart the computer, update BIOS and only your answer helped me
Thank you!!!!!!!!!!!!!!!!!!!!!!!
I signed up to the site just to thank you
Well you can try the following solution
For more you can read this
Hi,
Here's a link regarding what to check if the Windows key is not working.
Ultimas 24 horas: 5
Ultimos 7 días: 15
Ultimos 30 días: 33
Todo El Tiempo: 203
