How to fix iPhone xs max screen port broken
I fixed my phone 3 times and one time I made a mistake and broke one of the pins from an iPhone xs max screen port can someone show me how to fix it
Es esta una buena pregunta?
Hi Ramses,
@imicrosoldering, AKA Chris is our resident expert on microsoldering, which is what is going to be required to fix your phone. I'll tell you what I know, but he's the authority on things like this.
First off, the circuit board on your phone actually consists of two boards sandwiched together, and to properly repair it my understanding is that the boards need to be separated first, which requires specialized equipment and expertise. Once the boards are apart, a heat gun usually used to remove and replace the connector, and again, it takes an experienced technician to do it right and not cause further damage to the board.
The upshot is that unless you are experienced in microsoldering and have the proper equipment, this is a repair best left to a professional. I consider myself fairly experienced at soldering, but this isn't a repair I would attempt.
You will want to find a repair shop qualified to replace the OLED FPC connector to do the job. They should be able to give you a reasonable idea of cost before they start and should stand behind their repair in the case of any incidental damage they cause in the course of the repair.
Hopefully Chris will hop in here to correct anything I've gotten wrong and add any further information you need to know.
Fue útil esta respuesta?
You are correct Jerry. The pads look alright so it will be a straight forward repair for a reputable repair shop.
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 73
4 comentarios
Hi Ramses,
Which connector specifically is broken; there are three connectors going to the screen, the OLED connector, the digitizer connector and the front sensor connector. Is it the part on the cable or on the motherboard?
If you could post pictures of the damaged part, that would help us figure out the best way to help you.
Agregar imágenes a una pregunta existente
- de Jerry Wheeler
here I can send you a pic
- de Ramses Rodriguez
@ramsesplayzyt Please post it to your question; that way others besides me can contribute to the discussion. Note that images can't be posted to comments, so use the guide I mentioned previously to add it to your question.
- de Jerry Wheeler
Ok done I added the image
