Saltar al contenido principal
FFFH20F3WW - Condenser fan runs continuously
Hi, I have a frigidaire upright freezer that the condenser fan seems to run continuously. Freezer seems to be cooling correctly, with recommended being about -22C, and max being close to -30. Door switch is working correctly, and it seems like compressor and interior fan are cycling properly. I am just not sure if it is normal for the condenser fan to run all the time.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi
Do you mean the evap fan as looking at the parts for the model, (supplier 1, supplier 2 ), it doesn't appear to have a condenser fan (you mentioned both fans), although the wiring diagram does show it. It is a bit confusing.
If it has a condenser fan and it is running continuously, looking at the wiring diagram it is powered directly by the control board. A lot of condenser fans have a thermistor/thermostat connected which is set to operate the fan if the temperature near the condenser exceeds their set range. The wiring diagram doesn't show one for the fan and no parts suppliers even lists the condenser fan as a spare so it can't be checked visually online.
Have you checked if the condenser coils are clean and free of dust etc? If the condenser coils are clogged up the heat absorbed by the refrigerant as it passes through the evaporator unit cannot be dissipated as quickly as it should be, when the refrigerant passes through the condenser and this reduces the cooling efficiency and the fan may be running all the time to cool it down to the required temperature.
Also if the temp in the freezer is getting down to -30°C this is lower than it is set for. The diagram shows that the set range is 4°F (-15°C) to -4°F (-20°C) Your temps are in the range of -7.6°F (-22°C) to -22°F (-30°C). It seems that the range limits may have shifted, unless the temp gauge is wrong ;-)
If it is getting too cold then perhaps there's a problem with the temperature control thermostat (p/n 5304513033)
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Hi, it is the condenser fan for sure. I removed the back panel yesterday to check and the coil is clean. The compressor was completely cool and seems to be cycling properly, and the freezer is holding at recommended temp setting about -3 to -4 F. Here is the parts list for the unit. https://www.reliableparts.ca/lookup/3064...
- de
Hi @Ryan,
It's very odd because there's no sensor for the condenser fan (definitely the correct wiring diagram linked above - part number of diagram matches what is shown for the wiring diagram on the cover sheet in the parts link you posted).
It's only a two wire fan and the power for the fan comes from the control board. (AC voltage section J1 connector pin 3).
Perhaps it is designed to operate continuously regardless of whether the compressor is operating or not. In the wiring diagram it states that when entering service mode:
"Test 1: Compressor and condenser fan:
The compressor and condenser fan turns ON as soon as service mode is activated.
If it is designed to only operate when the compressor is operating but it is still operating when the compressor is off, then the problem must be on the control board.
- de
Añadir tu respuesta
Ryan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 43
Todo El Tiempo: 239
