MUST READ FOR EQUINOX ABS SENSOR ISSUES
Most mechanics do not think this far a head as the problem can be caused multiple things.
The most common is the wheel bearings wear out causing the break sensor to touch the hub causing the sensor to error out.
If it happens to one bearing the rest are going to be bad soon. So fix them all.
The good thing is the fix is relatively easy. The bad thing is the parts are a little pricey.
You'll have to replace all the wheel hubs to fix the problem.
Here is another part that also requires attention and repairs to fix the ABS errors. If any of the other parts in the suspension are worn it will affect the rotation of the wheel and sensors, mostly when breaking. Example: if the front struts are worn out or have lost the gas charge the wheel will have some "chatter" when breaking. It may not be noticeable to the driver or you may not feel it in the steering wheel. However, the wheel sensor picks this up as loss of traction. So, if you replaced the hubs and you are still having the same issue, replacing the struts along with the wheel hub could fix the problem. Have your mechanic look at the rest of the suspension parts to ensure there are not any issues.
Another benefit to repairing the worn suspension parts is your vehicle will drive nicer and will be much safer to drive.
As you were told when you were a kid, "pay attention".
29 comentarios
can the tcs cause you vehical not to start
- de La Verne Walker
will the traction control shut down the engine.
it will not shut the engine down but it can cause power loss and no acceleration
- de Jimfixer
Well im having problems with my back brakes sticking and releasing sometimes. Its light something holding my speed back wile drivin down the road. What can no of part I need to fix this problem
- de Travis Blue
I just replaced the front passenger bearing because my bearing was shot and my abs n tc (traction control) light was on it went off after I replaced my bearing about 3 days after the abs and tc icon light came back on so I checked the abs wire behind the tire connected to the hub bc in my case it's a sealed unit. The wires looked good and were connected I turn the car on and off and the icons go away shortly after the icons the icons come on again constantly. Any suggestions
- de Dyvane
Mostrar 24 comentarios más
