Saltar al contenido principal
I have a 2005 pontiac grand am se security light on constantly and no
I have a 2005 pontiac grand am and the security light is on but not blinking. If I turn the key the dashlights, windows,lights, and the cd portion of the deck works. Also, The car will go out of park without the key in. The door fob wont work at all anymore. I have tried the bypasses but none of them work. The mechanic says the code is saying that the ignition is not communicating with the starter. I have changed the battery. The fuse to the ignition, ignition and the switch ( parts from Autozone) and the starter relay, the car will start for a second if I engage it using a screwdriver and pull on the gas but only for a second. I called a locksmith that was supposed to be able to reset the security but was stumped because the turning the key on and off method for 10min and 15 secs 3 times didn't work. Can anyone please help me with any direction of where to start.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
If you used a screwdriver to turn the lock cylinder/ignition switch, irreparable damage may have occurred to the lock cylnder (where the ignition key fits into) as the lock cylinder has a magnet that passes under GMS Passlock sensor as part of the antitheft system. This problem may be complicated insofar as restoring/repairing security or bypassing it entirely (provided it can be done with a damaged sensor. Here's background info for you or someone familiar with GM security systems; https://www.tradecraftspecialties.com/Pa...
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Vernice D. Arnold estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 59
