Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Versión solo con Wi-Fi del iPad Air de segunda generación de Apple. Modelo A1566.
My Wifi is Greyed out, How could I fix it?
I have tried a reset and done everything WiFi works over Bluetooth using my iPhone but is very slow, It used to work just fine but now it doesnt it is a 16GB iPad Air 2.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
1 comentario
Why hello Xavier. Trying to fix your iPad lol The wifi antenna might be bad.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
This will not be an antenna issue. If the Wi-Fi is greyed out you defiantly have a board issue. You will need to check that the Wi-Fi chip is getting power, if it is you will need to re-ball or replace the chip. If it isn’t getting power you will need to find the faulty component that has failed. Microsoldering will be needed to fix this problem.
Fue útil esta respuesta?
Puntuación 4
1 comentario:
UPDATE: I just plugged it in and powered it on for the first time in a month, Wifi is back so I think it keeps getting overvolted or something like that.
- de
It sounds like it could be an issue with the Wi-Fi Antenna. If you follow this guide to check the state of the antenna. I would attempt to reseat the antenna before attempting a replacement. Otherwise, it sounds like it could be an issue with the logic board.
Puntuación 2
1 comentario:
- de
Añadir tu respuesta
Xavier K estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 29
Todo El Tiempo: 1,826
