Why is my left side fan work at random?
The fan on the left is almost never working as it should, its at 100% speed while idle and stops while gaming. Starts/stops randomly.
Es esta una buena pregunta?
Hi,
Don't know the laptop but first check in BIOS to see if there are any fan settings or other information regarding the fan, that can be altered and see if that changes how it operates.
It could also be that the fan is intermittently faulty of course.
Here's the hardware maintenance manual for the laptop from this support webpage.
Go to p.35 to see how to remove the thermal module. This will allow you to check if the fan connection is OK etc.
Fue útil esta respuesta?
I checked the bios nothing there this is most likely a faulty fan, seems to be a common problem in this model for some reason
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 417
