Saltar al contenido principal
El Xiaomi Redmi Note 9 es un smartphone de gama media de Xiaomi lanzado en abril de 2020. Tiene una pantalla LCD IPS de 6,53", una cámara principal de 48 MP, un sensor de huellas dactilares montado en la parte trasera, una batería de 5020 mAh y funciona con un MediaTek Helio G85.
Device reboot continously when in Standby-mode
Good Morning,
i have the phone of my mother in law and it's rebooting continously when in standby. as long as the display is on, you can use the phone normal, but after locking it device starts to reboot again and again. did someone have this before?
btw: Chargng is a little bit slow, but i think it's because of the reboots (more power needed).
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
Have you tried to update software or firmware? It could maybe be a Internal Issue but im not sure what would cause it.
- de
this is impossible, because when i tried it it fall back to bootloop at 64% Updated.
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
@m0ddmylife
What happens if you start the phone in safe mode?
If still no good, here's a link to the schematics which may help as it has Level 1, 2 & 3 repair instructions.
I haven't tried this link but have used the website before for other makes and models and they were OK.
Fue útil esta respuesta?
Puntuación 1
Your smartphone might experience a reboot loop if its cache memory is full. To test for that possibility, you should empty your phone's cache
Regards,
Will
Puntuación 0
1 comentario:
I've set it back to Factory mode multiple times, so this is not working.
- de
i have a had the issue a couple times what i do to fix this is, is to hold the power button until the lock screen appears
Puntuación 0
Añadir tu respuesta
Michael Kastner estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 46
Todo El Tiempo: 1,048
