How to use earphone type c on samsung galaxy a11?
Es esta una buena pregunta?
Hi,
You may be able to plug the USB-C earphones into the USB-C port on the phone.
I'm not sure if your model allows audio through the USB-C port or not as the user manual doesn't show all the available settings.
Go to the Settings > Developer Options > Media > Disable USB audio routing and check that it is NOT enabled.
Here's a video that shows how to get enable Developer Options.
If the Disable USB audio routing setting is not there then I think that as you obviously cannot connect USB-C headphones to the headphone jack in the phone, you would need to use a 3.5mm male to USB-C female converter (you need to convert from an analogue signal to a digital signal) and they don't seem to be available. At least I couldn't find any.
Fue útil esta respuesta?
Ultimas 24 horas: 3
Ultimos 7 días: 18
Ultimos 30 días: 99
Todo El Tiempo: 2,571
3 comentarios
Why not just use the headphone port?
- de [deleted]
@strongbow
I took it to mean the the OP had headphones which had a USB-C connector and not a 3.5mm plug.
Cheers
- de jayeff
@jayeff I've no idea. I was confused because the phone already has a headphone port.
- de [deleted]
