Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Flagship smartphone from Huawei released April 2018. Model CLT-L29.
Why are there vertical black lines after an LCD repair?
Hello, I have replaced the LCD screen for my Huawei p20 pro. The phone turns on fine but there is a thick black vertical line running down the display screen.
I have checked the connection which is secure and hope I haven't damaged the flex cable as I was super careful! Is there anything else I can do?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Farhan Shahid, if you checked your connector ends (both and those look ok, double check the cable for tears etc. If all that checks out ok, contact the seller and replace the screen. It's possible that you have a bad screen. Happens more often than we hear about.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Farhan Shahid estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 380
