Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Why is help displayed in the camera data display window?
After installing a fresh battery the word "help" is displayed in the data display window of the camera. There is no function when the shutter release is pressed, no film advance nothing is working.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @cuzz
According to p.94 of the user manual, help indicates a winding motor problem.
The solution offered is to remove the battery and then re-install it.
What is the battery charge being shown by the 4 bar indicator in the data panel when you turn the camera on?
Just verifying that you installed a 2CR5 Lithium battery? Maybe check the voltage of the battery. It should be 6V. The shutter is locked when the battery has been depleted.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Daniel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 23
Todo El Tiempo: 793
