Saltar al contenido principal
The Samsung Chromebook XE303C12-A01US laptop features an 11.6" screen and a 16 GB SSD hard drive. This small notebook computer allows for easy access to the Internet and can run various web apps.
Preguntas 36 Ver todo
What should I do? Been trying to fix this.
been trying to download Chrome recovery utility
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
5 comentarios
What kind of storage does this device use (SSD, HDD)? My thought process here is that either the device that the recovery is being downloaded to has corrupted storage, or the device you are trying to recover has a corrupted drive. If neither of those are the case, I would recommend re-downloading to make sure it wasn't just a corrupted file.
- de
I did it, I re- downloading I've been trying since afternoon.
- de
I don't know if ssd or HDD
- de
@febbyyy, it appears you'll need to use a different computer to create the recovery media. Do you have access to another computer to do that?
If you haven't seen it already (and it sounds like you have), here's a link to the recovery instructions for chromebooks.
How to recover Chrome OS to its original factory state
- de
Yes I already try to another computer.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@febbyyy Just confirming the process you took.
On a separate computer, you installed Google Chrome, then installed the Chromebook Recovery Utility.
You inserted a blank USB Flash drive with at least 8GB of space into the computer.
You clicked the puzzle piece labeled extensions and selected Chromebook Recovery Utility.
You clicked "Select the model from a list", then put the correct manufacturer and model number in, and clicked "Comtinue".
You selected your USB drive from the drop-down menu, then selected Continue>Start Now, and waited for the USB drive to be flashed.
Did you get this far?
Source
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Rica manlapaz estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 63
