Desplázate por este tema para encontrar el lugar apropiado para este comentario. Luego haz clic en "Añadir comentario a esta publicación" para moverlo.
3 comentarios:
Hi,
Does it restart automatically after it has turned off and does it stay off until you restart it?
Can you hear if the fan is running and is the fan exhaust vent clear and not blocked with dust etc?
If not it may be overheating and shutting down to prevent damage to the CPU.
Does it do this if you start the laptop in safe mode?
Hi,
- de jayeff
No it only turns off when i turn it on and it stays off untill i turn it on again .
I tried to hear if the fan is running but the fan makes a slightly noice so i guess it may be blocked with dust
It all started when i put my laptop on sleeping mode for 5 hours then when i came back this problem happened .
I watched a similar problem on youtube and they say u might need to clean the ram with a rubber
Thank you jayeff <3
- de Bilal Blackops
Could you install a thermal monitoring program to see the temperature of the CPU?@Bilal Blackops
- de Duck
