Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Radio isn’t getting power.
What do I do if my radio isn’t getting power
Update (08/28/2022)
@oldturkey03 I checked the fuses that are on the side of my dashboard and they have power I was told to check if the wire had power going to it but it didn’t.
Update (08/28/2022)
Yes the radio is factory.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
@juanherna use the wiring diagram to see what is going on with your radio. The fuse box on the L side has fuse #37 which is the radio fuse. It is a 20amp fuse so make sure you only use a 20 amp to replace it. After that trace the power wiring and see where is stops.
Imagen
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Juan hernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 1,150
