Saltar al contenido principal
El HP Flyer Red es un portátil creado por Hewlett Packard que se lanzó alrededor de diciembre de 2014.
Preguntas 31 Ver todo
My hp f272wm will not turn on! What do I do?
My hp f272wm has the charger light on but that is the only thing that is on. But when the battery is in it will blink red fast then blue long then red fast then blue real long then blue twice and the blue twice will repeat. But when I take the battery out it is solid blue but when I hit the power button it will not turn on.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi @dan2014 ,
Try a power refresh and check if that resolves the problem.
  • Disconnect the charger if connected and then remove the battery from the laptop.
  • Press and hold the laptop's Power On button for a full 30 seconds and then release it.
  • Reinsert the battery, reconnect the charger and check if it turns on.
If still no good you may have to remove/replace the RTC battery from the systemboard as well and check if doing that fixes it.
Here's the maintenance and service guide for the laptop that may help.
Go to p.57 to view the necessary pre-requisite steps and then the procedure to remove/replace the RTC battery.
I'm not sure that you have to remove the systemboard as I think that the battery should be visible once you can access the systemboard.
Once you have removed the RTC battery, measure its voltage. It is a 3V Lithium battery and usually lasts about 5-6 years. If it is <2.5V DC, replace it. Search online for 697917-001 to get results for suppliers that suit you best.
Reinsert the RTC battery (or its replacement), reassemble the laptop, reinsert the main battery, connect the charger and check if it turns on.
Fue útil esta respuesta?
Puntuación 2
8 comentarios:
Two nails are being very stubborn
- de
Also there is an error code that is not listed on Hp's web site. But I can tell you.
- de
@dan2014
Please tell what the error code is?
- de
Slow red, fast blue, slow red then blue real long [happens one time when getting power] then blue fast twice [will keep repeating].
- de
@dan2014
Can't find anything re a blue power light flashing, only red + white codes.
Did you manage to get the RTC battery out and try the reset as described above.
Other than that it is a motherboard fault and you'd need the schematics to find out what's wrong.
- de
Mostrar 3 comentarios más
Those flashes of light are error codes, and they occur in specific patterns to indicate what is broken/needs replacing. HP's website has a list of error codes, their meaning, and how to fix them. Is your error code on the list?
HP Desktop PCs - Computer beeps or a light blinks during startup
Puntuación 0
3 comentarios:
First my code is not listed. Second I made a mistake the code was slow red, fast blue, slow red then long blue. but the blue twice was right.
- de
If you didn't see your error listed, upload a video of the error code you are seeing.
- de
I can't but I can tell you
- de
Try this methods given below-
1. Check the power supply and battery
If your HP laptop won’t turn on even when plugged in, start by checking the power supply. There are quite a few issues you could have with the power supply.
For example, the problem could be as simple as having the wrong charging cord which means you aren’t getting the proper voltage, or it could be that the power supply has failed [2].
To test if the power supply is the issue, completely remove your laptop battery.
Then, plug your laptop into a functioning outlet.
First, confirm the outlet is functioning properly by plugging another device into it - if it works, the issue isn’t the outlet.
If you can power on your laptop without the battery installed, the issue isn’t the power supply, it’s your battery.
You’ll need to buy a new one but, in the meantime, you can simply use AC power only.
It’s perfectly fine to use your laptop without the battery installed, it just means you’ll always have to be plugged into an outlet to use it.
CMOS battery
One other possible solution to test out is to replace the CMOS battery which stores the BIOS settings in the motherboard [3]. This is especially true if you're running an older laptop that is off a lot or used with the main battery removed. A new CMOS battery is very budget-friendly to replace.
Pro tip: Make sure that the cables are all properly connected. This might seem simple and obvious but most issues with a laptop that won’t turn on stem from a power supply issue. A loose or unplugged power cable means your computer isn’t getting the juice it needs to run.
2. Diagnose screen issues
If your power supply is working, you will need to troubleshoot further.
First, disconnect all of your nonessential external display devices like projectors and monitors to make sure they’re not interfering with the startup processes of your laptop.
If the power button is lit and you can hear fans or noises but there isn’t an image being displayed, turn out the lights to see if there’s an image being displayed very faintly.
If there is a very faint image once the lights are off, the screen’s inverter has failed and you’ll need to replace it [4].
Alternatively, your brightness button may be broken.
If your laptop starts up but there isn’t an image, the LCD panel could be broken. It’s not impossible to fix a broken screen, you can read our article here about how to do so. But if your laptop is an older model it might make more sense to simply replace your entire laptop.
3. Remove all devices from your laptop
If you have left a memory card, DVD, or USB drive in your notebook, this could be a reason why your laptop doesn’t power on.
It might be getting “stuck” because the BIOS may be trying to boot from a removable storage device. Remove all USB drives and other devices and try to boot up your computer.
4. Use a rescue disc
A rescue disc allows you to boot your computer and fix any issues you may be having with a Windows operating system [5]. If a virus is the culprit behind your computer problems, the rescue disc will find it via scanning tools so you can remove the offending malware.
5. Boot in safe mode
If your HP laptop won’t turn on you might still be able to get your laptop working in safe mode [6]. Safe mode allows you to uninstall new programs or drivers that could be affecting your laptop. It also allows you to create a new user account if your original account has been corrupted.
6. Check hardware
The last step when diagnosing power issues is to check your hardware. If you’ve recently installed hardware like a new RAM kit, that could be the cause of your boot issues. Remove and reinstall your new hardware and try to boot again.
Unfortunately, sometimes the hardware in your laptop such as your hard drive simply fails and there is no easy fix. If you hear a clicking noise or the drive spinning but then powering down, this is a telltale sign your hard drive has failed [7]. In most cases, this means you’ll need to simply replace your hard drive.
In instances like this, it is smart to have an external hard drive so you can back up any files you may need.
Greeting,
Rachel Gomez
Puntuación 0
1 comentario:
#1 I have seen that article on hp tech takes. 2 I tried that. Did not work.
- de
Añadir tu respuesta
Dan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 358
