Saltar al contenido principal
The Dell OptiPlex 7010 MT is an office-oriented desktop PC. It comes with a third-gen quad-core Intel i5 or i7 CPU. It has 4 DIMM slots, 10 USB ports, two hard drive bays, and two DVD drive bays.
short in circuit power
No power, no data the power supply is working fine
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
2 comentarios
Hi are there any harms or burns on the board that you can see with a close inspection
- de
Hi,
Please elaborate what you mean by no power?
Is there an amber or white light on the Power on button when you press it to start the PC and if either is on is it steady or blinking?
If the light is amber and it is blinking is there a pattern to the blinks i.e. count the number of blinks e.g. 2 blinks > short pause > 3 blinks > longer pause > then 2 blinks again etc
You said that "power supply is working fine", did you use the PSU diagnostic test on the back of the PC to check this?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
have you checked reseating removable parts? like ram hdd pcie slot graphic card , i have had a similar problem but with the hdd i have switched to a ssd and the problem was fixed for me.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Meo Roo estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 234
