Saltar al contenido principal
La tarjeta microSD de SanDisk es un dispositivo/medio de almacenamiento en formato TransFlash/microSD. Los estándar vienen en todas las capacidades diferentes, hasta 2GB. Fue lanzado en octubre de 2001.
Preguntas 16 Ver todo
What information should I put?
I'm trying to see all the past photos and videos of my SanDisk MicroSD Card 2GB trough USB in Windows 10, but it says I need to "Format" it first to use it, but I am confused on what setting I should insert, (Specially the "Volume" ).
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi,
Do not format the card!
If you do a full format on the SD Card, you will lose all your files (photos and videos) that are stored on the card. They will be erased.
If you do a quick format, the file address table on the card will be erased, which is essentially the same thing as you won't be able to retrieve files, at least not easily.
If Win 10 shows that the card needs to be formatted it can't read the card so either the card is faulty or corrupted or the USB SD Card reader may have a problem. Can you read other SD Cards OK using the card reader?
Where was the card previously inserted? If it was a camera can you view the files from the card in the camera at all?
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Omali Y. Martínez Rivera estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 95
