Getting a code F:01
My washer starts then stopes with code F:01 and I don't know how to reset it. Never had any problems with the machine in 5 years.
Model # MVWB450WQ0
Es esta una buena pregunta?
Model # MVWB450WQ0
Hi,
Here's the Tech sheet for the washer.
Run the Automatic Diagnostic Test mode as described on p.1 to verify that the error code is an F01.
If it is then on p.3 it indicates a Pressure Signal Out-of-Range problem - see possible causes.
If the pressure hose is OK go to p.4 Test #3 Motor Circuit to see if you can determine whether the motor or the MCU (Motor Control Unit) is the problem.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 250
