Water Marks Under Display after using Alcohol to help remove battery
I usually use Isopropyl Alcohol to help soften adhesive to remove phone batteries, and usually its ok, but with this iPhone 4s I must have either used way to much or it can seep under the display easily. I did see slits in the housing right where the battery is so im assuming that's the issue.
My question is, is this display permanently damaged like this or can it dry out after awhile?
Es esta una buena pregunta?
