Can I pair a new baby unit to an existing parent unit?
We lost our original baby unit, and I found another one on fb marketplace, will I be able to pair the new baby unit to our parent unit?
Es esta una buena pregunta?
Hi
You could try but I doubt that it will work.
I think that these units are somewhat like wireless keyboards connected to a PC. The receiver plugged into the PC and the keyboard are already paired by the manufacturer. I think it is the same with the baby monitor as there is nothing required to "set up" the connection between the two units. Simply plug both units in and they should connect.
This is to prevent interference from other identical devices or to prevent access from other identical devices using the same system. In your case you wouldn't want someone else having the same unit having access to your system.
Fue útil esta respuesta?
Ultimas 24 horas: 5
Ultimos 7 días: 16
Ultimos 30 días: 65
Todo El Tiempo: 568
